Breakout view limitation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Apparently, creating a breakout view for any other view from base is limited to one breakout view in any view. What is the reasoning for this terrible limitation? Is it a function of the "Not for Commercial use" or is it for all options of Fusion 360? If it is a limitation for Non-commercial, okay, it's a bad idea, and should be re-evaluated. If this limitation exists in Fusion 360 products, it's a product design issue that should be addressed. Many large machine tools will require multiple breakout views within a single view to accurately represent hidden details in a specific area within a larger view. One such machine comes to mind. The broaching systems used to machine automotive engines and transmissions. Some of those broaching systems will have frames 20 ft. long with several areas needing breakout views to dimension the details. Why would this feature have a limit at all?
Thanks for your time
Mike B.
