boundary surface out of curve network in Fusion possible?
cekuhnen
Mentor Mentor
cekuhnen
Is something like this possible? I was not able to do so!
https://www.youtube.com/watch?v=RsTNsTz64Jg
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
innovatenate
Autodesk Support
Autodesk Support
I see that you've posted some ideas related to this topic in the IdeaStation. I thought I would link them here.
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/curve-network-command-needed/idi-p/47...
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/extracting-curve-layout-auto-update-s...
What about using the Convert command to convert a B-Rep Surface to a Sculpt (T-Splines) body? It seems like using the symmetry tools in the Sculpt environment could save a lot of effort. There would be no need to fix a degenerate point or create an additional blend surface.
You may use the Include 3D Geometry command and manually project the control edges of a Sculpt body to generate a "faux" curve network. Depending on the sculpt body, this could be a lot of work. I don't think there is a "true" curve network command, available at this time.
Nathan Chandler
Principal Specialist
cekuhnen
the problem I have with TS is the surface quality - so TS is not in each situation ideal.
BTW some of those ideas were posted nearly a year ago and I never heard back - specifically the lack of a blend curve still I think hurts the tool set.
Splines and constraints/handles are sometimes extremely hard to work with compared to a blend curve or cv curve.
Claas Kuhnen
