BOM Error showing all the sub-componets
colemanHEXZG
colemanHEXZG
I am having issues with creating a BOM for my assembly. Initially, I just wanted to hide parts in the PCB to so they wouldn't show up in the BOM, because right now it shows each part in my BOM from the PCB. I had my Electrical guy export it differently so that they aren't all separate bodies, but now the BOM won't even be created.
So ultimately I'm wondering is there a way to make one of these files show a BOM without all of the sub-parts under it?
jhackney1972
You need to attach your Native Fusion Assembly file not a STEP.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
colemanHEXZG
Sorry about that. Here are the native fusion files. I thought you would want the STEP files but here you go.
jhackney1972
I tried all my tricks but Fusion refuses to only show First Level components in the 2D Drawing.  I hope someone else can pull a rabbit out of the hat and give you a solution.
