Body not solid...
Body not solid...
kristiankynk
Observer Observer
Body not solid...
kristiankynk
Observer
Observer
Hi!
Have been strugelling for a while...
My latest "design" renders out somehow strange, not like my all other 3D works 😄
It's like...lines, not solid body. I have hard time to explain...
https://a360.co/2GeBMkD
wmhazzard
Could it be because you have PET plastic assigned to the material and the appearance is the same, so the part is clear?
kristiankynk
Observer
Observer
Actually i thought it might be.
And restored the settings to default. It did not change anything. ...but now i imagine that this doesn’t change the material settings for bodies created so far, but everything created after..? Am i right?
wmhazzard
For some reason the transparency effect can't be undone and it should be able to. A new body that is created shows as the standard steel.
wmhazzard
I got it, the opacity of the body was turned down. Right click on the body and select opacity control and select 100.
I am too facing the same problem! How did u got it resolved?
TheCADWhisperer
@Anonymous
