Body not selectable, not hideable, no command for body creation existing
Florian__
Florian__
I'm trying to thicken a surface. Therefor I changed the thickness a view times. Now there is a body that I can't hide and can't even select in the window.
What can I do to delete or hide this body?
The fusion files are attached and the issue is shown in the screencast below.
Thank You!
dsouzasujay
@Florian__ ,
I see you have missed to add screencast video.
Did you try Hiding/Unhiding the bodies by expanding "Bodies" the fusion browser tree?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
shahriarsifat1802164
I can not see any screencast here.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Florian__
<iframe width="640" height="590" src="https://screencast.autodesk.com/Embed/Timeline/bc77ba56-00ff-4cc1-813a-f9125c388145" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Florian__
Here you can see the issue. Thank you guys so far!
Florian__
It seems after reopening the document the body75 is gone. And @dsouzasujay has no body75 when he opned the save document. Seems to be a bug..
dsouzasujay
@Florian__ ,
I tried to thicken some of the surface but i was not able to reproduce the issue.
Looks like the browser did not refresh and the body didn't  got removed.
If you can see the issue again try Compute All.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
