bodies still disappear in the browser
cekuhnen
Mentor Mentor
cekuhnen
I just stitch two objects and while the objects remains listed in the browser visibility wise it is gone
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
jeff_strater
this design has one surface body, and one solid body that are invisible. Is this the "after" state? So, presumably, in the "before" state, there were bodies that were visible, but when you stitched them together, the result was OK, but was just invisible?
Just trying to make sure I understand the problem
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
cekuhnen
stitched and then invisible
Claas Kuhnen
jeff_strater
Interesting, thanks. I have not yet been able to reproduce this. By chance do you have the "before" version of this? By some weird sequence of events, I don't actually have the release that you have (we pulled it because of the config problem), but I've tested it on the current production build and our internal main build. I'll keep trying...
Jeff
Jeff Strater
zhanganchun
Seems the model is a little corrupted, you can also try compute all to fix the model first.
Terry
Software Engineer - Fusion 360
cekuhnen
yep fixed the issue as well
Claas Kuhnen
