bodies not showing up in list
Message 1 of 8
I have been working in the same file all day and the last two bodies I created (camshaft and valve set) do not show up in bodies.  I have provided a picture, which shows what I'm referring to.   I turned all the bodies off in the list individually, but the two bodes you see do not appear to be in the list.  I usually save them in .STL to print from the bodies list.  Any help is appreciated.
Replies (7)
Message 2 of 8
SaeedHamza
Make sure you didn't make them components, because if they were, they won't appear in the bodies menu
If this didn't solve it, please go to file > export > .f3d and attach it to your next post
Regards
Saeed
Saeed Hamza
Message 3 of 8
davebYYPCU
More recent bodies will be lower down, scroll down, cause we can't see the end of the list at the moment.
Message 4 of 8
Thanks for the help.  I appreciate you taking time to answer.
Message 5 of 8
Dan.G.Beare
I'd just like to add that this was actually the solution!
I am a total beginner at Fusion 360 & I almost ignored it as the actual answer to the problem because it was such a stupid beginner mistake/overlook.
I am trying to edit a .stl mesh/Brep file so there are a lot of Bodies to start with! (116)
I was going crazy trying to figure this out as it looked like the new body (117) was/should be in the list but it was not visible!
I thought there were only 41 Bodies in my list & didn't realise there was a scroll bar on the side! Ooops!!
Thanks for the help!
DAN.
Message 6 of 8
Dan.G.Beare
(I've now cleaned up the menu by grouping the original bodies (116) into a new Folder...)
Message 7 of 8
TheCADWhisperer
@Dan.G.Beare
Here is another tip.
You can use the Windows commands Shift Win S and Ctrl v to grab clear screen capture images and Paste them here.
Message 8 of 8
Dan.G.Beare
Thanks for the tip @TheCADWhisperer😁👌 ... I now have multiple folders to keep organised! haha
