Blurry design visualisation
Sometimes the design is blurry, and normally it is sharp. When it goes blurry it is hard to select anything.
Is there an option to turn the blurry thing off? I think it something connected with antialiassing or something similiar.
Thanks in advance,
Krzysztof
jeff_strater
Hi @Anonymous,
From the images, it doesn't look like a question of "sharpness", so much as edge display somehow got turned off in the "not sharp" case:
Screen Shot 2017-06-28 at 7.40.31 AM.png  Screen Shot 2017-06-28 at 7.40.41 AM.png
Can you check that you have edge display turned on:
Are there any other circumstances that you can describe when you see this?
Jeff
Jeff Strater
Engineering Director
TrippyLighting
My suspicion is that he's working on an older computer ( like I do 😉 ) and it takes a while for the edges to appear. On my mid 2010 i7 iMac it can also take a while sometimes for the edges to appear if I have  lot of geometry on my screen.
@Anonymous Maybe try to disable some of the graphics gimmicks. To do so you click on the question mark in the upper right corner of the Fusion 360 window and elect Graphics diagnostics. The Dialogue has a check you might want to try enabling and see if it makes any difference.
Thanks guys.
I didn't have "Shaded with Visible edges only" selected but as you said when orbiting around there is need to wait so the edges could appear. This is most probably due to older computer I use. 🙂
Thanks to solve the ridle.
Best regards,
Krzysztof
