Blum hinges
Blum hinges
potlsnekkeri
Message 1 of 27
Blum hinges
potlsnekkeri
hello
i need to import blum hinges into my prodject where can i find it
i have tyred tracepart but cant find it?
Replies (26)
Message 21 of 27
potlsnekkeri
thanks, what file format shoud i use then?
Message 22 of 27
andy.griffinP6ZT8
I download the parts I need as *.step. You will need to joint the components. I usually rigid group them together because I don't need any movement.
Message 23 of 27
TrippyLighting
@potlsnekkeri wrote:
ok thanks i will try this ,what file format shoud i use then?
STEP
Message 24 of 27
potlsnekkeri
https://a360.co/3dsy47b
Hi, I've gone a step further, I've imported hooks and parts for my model.
Can someone show me with a film how I can get the hinge mounted and can be opened, that would be great 🙂
Message 25 of 27
jhackney1972
The hinge accessory does not have any motion.  I added joints and motion to the hinge so you can use it to replace the one in your assembly if it suits.  Please note the one Joint I labeled "Hinge Limits" which you can adjust if I guess the hinge opening distance.  Hinge assembly is attached.
By the way, do not use the Quick Reply icon as this addresses your post to yourself.  Select the Reply icon on the person you are responding to.
John Hackney, Retired
Message 26 of 27
potlsnekkeri
thanks  for help .Is it possible to help me with the placement off the hinges ?screencast recorder? how i can get  the motion and get the hinges in place.
Message 27 of 27
jhackney1972
In the Screencast, which is rather long, I used As-Built Joints to add motion to the hinge.  As-Built Joints preserve the orientation of components to each other by placing the select joint between the origins of the two components.  It is not a type of joint you use in normal assembly but with the hinge, you want to keep the orientation of the components as you imported them.
As far as placement of the hinge between your cabinet and door, your model did not offer a suitable structure so I created a very simple assembly in order to demonstrate the hinge placement.  I am purely guessing on how your door is mounted, in relation to the cabinet, but I did it with an overlap flush mount.  Also I could not find instructions on the Blum site on how the mounting accessory hooked to the hinge so I just guessed.  Once you have the hinge in place, you can located screw holes and hinge cup cutouts.  Before you finalize these, you must secure a hinge, or find accurate instructions, to determine how the mounting accessory hooks to the hinge assembly.
On another note, you are dragging this Forum post out into multiple questions.  Please click the "Accept Solution" icon on the "many helpful replies" (you can do more than one) that have helped you and start a new Forum post for you next question.  You will get better and quicker responses and it cleans up the Forum a lot.
Model is attached.
