Blum hinges
Blum hinges
potlsnekkeri
Message 1 of 27
Blum hinges
potlsnekkeri
hello
i need to import blum hinges into my prodject where can i find it
i have tyred tracepart but cant find it?
Replies (26)
Message 2 of 27
g-andresen
Become a member of Blum E-Services.
günther
Message 3 of 27
potlsnekkeri
via fusion 360 or where to do that?
Message 4 of 27
jhackney1972
Try this address.  You will have to register, as mentioned earlier, to use their services.  When you find the CAD file, I doubt they will offer native Fusion 360 files so choose STEP or STP neutral format.  The hinge download will be static, if you want it to move you will have to add assembly joints.
John Hackney, Retired
Message 5 of 27
jhackney1972
Looking at their CAD data, it seems that they only offer 3D DWG files.
Message 6 of 27
jhackney1972
Attached is one of their hinges with most of the assembly joints added.  The component that would be screwed into the mounting pocket is Grounded.
Message 7 of 27
potlsnekkeri
thanks 🙂
Message 8 of 27
potlsnekkeri
how to import it into my model?
do i go to insert and then ?
Message 9 of 27
jhackney1972
As I mentioned earlier, they seem to only offer 3D DWG files so you will download their file, open it directly in Fusion 360.  Fusion 360 will have to convert it.  After that what you do with it is up to you.  If you need instruction on how to make it operational, that will have to be done via a Screencast.
Edit: After opening it, you will save it out as a Component and the insert it into your assembly.  Again, to make it active is another complete process.
Message 10 of 27
potlsnekkeri
you just sendt me a file ,and i tryied to download it into 360 ,it didnt work!!
Message 11 of 27
jhackney1972
Works for me!  I converted the file into Fusion 360 F3D format so you save it to your hard drive and the go to File, Open and select the file.
Message 12 of 27
potlsnekkeri
ok i use mac ,but do you open it from fusion360??
where??
Message 13 of 27
potlsnekkeri
got it thanks:-)
Message 14 of 27
jhackney1972
Here is a Screencast with the opening process for the file I attached earlier.  It does not matter the operating system you are using.  How long have you been using Fusion 360?
Message 15 of 27
potlsnekkeri
what do you use to convert file like this?
Message 16 of 27
jhackney1972
Are you reading my posts!  I told you that I downloaded a 3D DWG from the Blum site, and opened it using Fusion 360.  Fusion 360 will convert it automatically and ask you if you want to open it.
Message 17 of 27
potlsnekkeri
yes i read you post.if you read mine i sad that i get open it:-),it was a problem on my computer!!!
thanks for helping me out.
now i just need to find the other parts, cant just have the hinges
Message 18 of 27
g-andresen
Which license do you use?
As far as I know, converting DWG files is not possible with the personal license.
günther
Message 19 of 27
andy.griffinP6ZT8
That's not accurate. I use Blum E-services regularly and they offer downloads in various formats....
Message 20 of 27
potlsnekkeri
ok thanks i will try this ,what file format shoud i use then?
