Blend Tool in Fusion?
Hey guys I'm sorta new to Fusion and I was wondering if there's a way to blend two shapes together like you can in Illustrator.  I want to take two of the same shape and create equally spaced copies between them, I know about the pattern on a path tool but it doesn't quite work as well.  I've attached an example of this feature in Illustrator, thanks.  Capture.PNG
jeff_strater
The only thing that is close to this in Fusion are the various Pattern tools.  In the case that you illustrate, Pattern will do the trick.  I'm not familiar with Blend in Illustrator, so I don't know what the differences might be.  In my experience, you can get most of what you need out of pattern.  And, since we are on the subject:  Don't use pattern or mirror in sketch for large instance counts.  Use Feature or Body pattern on the resulting solids instead.  Those are much more efficient.
Jeff Strater
Engineering Director
