Blank grey window in A360
chrismasto
chrismasto
I have a design that works fine in Fusion 360 but when I post it to A360, the design view comes up as a blank grey window.  It isn't a browser problem, as I have tried both Safari and Chrome, and they work fine with other designs, just not this one.  I tried making a copy with Save As and uploading it as a new design, and it has the same problem.  Also, I can download the file from A360 and import it back into Fusion 360 and it works, so I think the file itself is being transferred, it's some sort of problem with the A360 service.
I reported this as feedback on A360 and had a few exchanges with someone, but ultimately he said I should post the question here to reach the Fusion team.
I have shared the design publicly here: http://a360.co/1Oo5H00 -- I've tried opening this on an entirely different computer and the same failure happens, so it shouldn't be hard to see what I'm talking about.  I can also attach some screenshots of the design overview page and the view page so you can see what I'm talking about.
Thanks for any assistance,
Chris
innovatenate
Autodesk Support
Autodesk Support
Thank you for submitting these files to use. I can reproduce the behavior on my computer with Windows 7 and Google Chrome. I believe there is something specific to the design that is causing this, but have not been able to pinpoint the root cause. I have submitted this to development for further investigate via a report (reference # UP-26101). We will investigate this issue further for the root cause and the solution.
If you have any questions, please let us know.
Nathan Chandler
Principal Specialist
