I'm trying to model a blacksmith tool, but for the life of me, I can't figure out how to create a curved sharp end. There's probably some extremely simple solution. I watched some tutorial on how to model a knife blade but it didn't seem to quite apply.
Could you advice me on how to create a constant sharp blade along the curve?
Solved by mango.freund. Go to Solution.
Not sure what you needed, from geometry in the file, used a bevel to the black centre line on the curved face.
Blue and green lines are not recommended, red icons should be attended to when they occur, usually Undo fixes it.
Make a cutter to take off the excess material, Split body with the cutter, and hide the offcut..
Might help....
