Best Worflow for join components after circular pattern
janus2
Message 1 of 15
janus2
Hello!
For example, if I have a circular hole pattern with 10 holes. Now I have to position 10 cylinders in these holes. These should rotate.
Therefore I position the 1st cylinder by revolute join.
Then I make a circular pattern for the other 9 cylinders.
Now I must define further 9 Joins.
But I have to move each cylinder away, otherwise I can't see the exact reference points for the join. (Not a simple hole but it has fine steps inside)
Then I have 9 unnecessary moves in the timeline. Now I have to delete them manually. Is there a simpler workflow?
Special regarding the unnecessary moves?
Jan
Replies (14)
Message 2 of 15
davebYYPCU
No need to move before jointing, Design dependent, you can use As Built Joint, or hide the Components while selecting the other.
Might help....
Message 3 of 15
MichaelT_123
Hi Mr Jan,
... without political correctness ... you are asking questions that should be obvious to most who have had done their homework reading/watching F360 reference documentation/tutorials
The workflow would be:
  • Have a KitKat
  • Stop ‘designing’ for some time
  • Study documentation
  • Have PrincePolo
  • Go to a sweet (no more bitter) design process
Regards
MichaelT
MichaelT
Message 4 of 15
janus2
As Built Joint is not a option,  because it is a revolute join.
Change visibility is a option, OK. But if the placement situation is critikal it is often better to move the component to place in a empty space to see clear where you set your join origin.
No real problem, I just wanted to make sure I didn't miss anything.
Jan
Message 5 of 15
TrippyLighting
An as-built joint it really the best solution here and in any situation where components are created in place.
You can make an as-built revolute joint or really any joint option is available as as-built joint.
Again, as long as the components are created in place by the patten command ( o so I assume) that works fine. Some folks use the move, or align tool to move components into pace and then use the as-built joint. That is not advisable, because you cannot delete the position capture features that you have to create.
IF these individual cylinders would not have to revolve a single rigid group joint to the seed instance would do the trick ... assuming that the seed instance has been properly joined.
As such I would urge you to look at if it is really necessary that these cylinder s rotate in the CAD design (not in reality).
Message 6 of 15
janus2
Hello MichaelT!
RTFM is always helpful advice. And so simple. It always fits.
But I did my homework. I can do what I want to do. But I am never satisfied and always looking for a better solution.
One day I might reach your level of divine enlightenment. Until then I will continue to ask questions here in the forum.
Have a nice day
Jan
Message 7 of 15
TrippyLighting
@janus2 wrote:
Hello MichaelT!
No it does not always fit and does not in this case.
But very often it does and I can see where @MichaelT_123 is coming from.
So if everyone can just please relax and have some coffee and donuts  (like this guy) that would probably help 😉
Message 8 of 15
janus2
Hello Peter!
That's a valid question.In most cases it is not necessary.
But I try to design an old calculating machine from the year 1700! So I do some (manual and motion link) simulation to see if all gear wheels, levers, springs etc. fit into each other. So I need this revolute join at this time in development.
As I said before: No real problem, I just wanted to make sure I didn't miss anything.
Thanks for your help
Jan
Message 9 of 15
MichaelT_123
All The Best Mr Jan in F360 enlightenment.
With Regards
MichaelT
MichaelT
Message 10 of 15
janus2
I think I've found a solution!
The cylinder was just an example. In reality it is an assembly. Now I have inserted a dummy element into the assembly. All other components can now revolve around this dummy element inside the assembly.
If I now use copy pattern for the positioning of the assemblies and then make a rigid group of the dummy elements, each Assembly can rotate in place.😁
I include a small test design if someone is interested.
Jan
Message 11 of 15
MichaelT_123
Hi Mr Jan,
I have to admit, it was the implementation of KKPP workflow strategy celebrated with the utmost devotion
even considering The History Of CADMen.
If it was not a miracle, what was it? No JOs in sight!
Keep it for the next X thousands of years,… in moderation, of course.
Sincerely
MichaelT
MichaelT
Message 12 of 15
MoshiurRashid
As built join it is...
Have a try
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 13 of 15
janus2
As build Join works as well. But I have to do it on every instance of the copied components.
With rigid group I can select all at once.
Jan
Message 14 of 15
janus2
Hello, Michael!
You may have noticed that English is not my mother tongue.
So I have trouble understanding your message. I understand the words but not the meaning.
What is KKPP-Workflow?
But as a start into the week I assume it was meant positively.
I wish you a good start into the week.
Jan
Message 15 of 15
MichaelT_123
Absolutely positively...
Read the context of my previous post.
It means: Kit-Kat - PrincePolo break.
Google it you do not know brands.
'Have a break, have a Kit-Kat'  - It is the brand's add/slogan.
I have tossed PrincePolo, which is equally good, if not better. (you might know it )
In more elaborate, verbose description It (supposed) to mean:
If you are struggling with some problem, have a break, think about it deeper, do not rush if you are not ready.
Regards
MichaelT
MichaelT
