Best way to resolve this shape
marcostocino
Message 1 of 8
marcostocino
Im recreating a lamp, the base and post are separate objects, whats the best way to create the pyramid shaped details?
I created a sketch then used the surface tools and finally circular pattern but im trying to find other methods (just curiosity) to resolve the problem. what solid tools can i try?
Captura de pantalla 2025-11-30 190838.pngCaptura de pantalla 2025-11-30 190818.png
Replies (7)
Message 2 of 8
kacper.suchomski
Loft (several times)
Kacper Suchomski
Message 3 of 8
TheCADWhisperer
@marcostocino
Message 4 of 8
marcostocino
Does this work? Any suggestion for better workflow and organized /robust file are welcome
Message 5 of 8
marcostocino
I tried loft before asking, the pointed edge didnt resolve well, can you share and example? Thank you
Message 6 of 8
TheCADWhisperer
@marcostocino
I did this while waiting for you to post your attempt...
Message 7 of 8
johnsonshiue
Hi! There are multiple ways to create the desirable geometry. I reworked JD's model and use Boundary Fill and Face Draft instead of Guide Rail Sweep and Point Loft. The resultant body only contains planar faces.
Many thanks!
Software Test Engineer
Message 8 of 8
marcostocino
Thanks for the solutions! i will look into the files for both ways. i need to explore Boundary fill more! interesting.
