Best way to import and combine meshes from Blender
TrippyLighting
Consultant Consultant
TrippyLighting
I've imported several things that I've initially modeled in Blender ino Fusion 360 (obj) and converted these into T-Spline models.
However in his case I want to import three differnet objets shown in the screenshot (from Blender) into Fusion 360 combine them and add mechanical features for assembly. Ultimately I want to create 2 objects  and export stl files from these to be 3D printed at Shapeways out of their Strong and Flexible nylon plastic.
What is the best way to combine these objects ?
I've removed the subdivision modifier from Blender and exported the control meshes as .obj files. then I imported these into Fusion 360 and converted into three separate T-Splines. Is this the correct approach ? What do I do then ?
BTW I run Fusion on a mid 2010 27" iMac with core I7, 12GB RAM and 1GB video memory and Fusion has been chewing pretty hard on the tube object for a while (10+ minutes) when converting it into a T-Spline. It also warned about graphics memory being low and turing of some features. Only antialiasing was actually left 😉
The screenshot below is from Blender's viewport:
innovatenate
Autodesk Support
Autodesk Support
It's difficult to tell what is going on from the screenshot. Can you post a screenshot of the obj freshly imported? Is that a bitmap texture or 3D geometry in the model?
Nathan Chandler
Principal Specialist
TrippyLighting
The image is what I want to end up with. No bitmap texture, all geometry 😉
in Blender they are just intersecting subdivision surfaces without any real interaction.
I have figured out how to join these separate T-Splines.
Here is a biger detail screenshot:
