Best practices: copy a body or component from one Document to another?
disneytoy
5,600 次查看
7 条回复
1 条消息(共 8 条)
disneytoy
Since I'm here I always wanted to know...
I have a "spindle" I designed in one document with lots of other bodies and components. I now want to bring just the spindle (body) into my new current design. I know I can't just copy and paste between documents. (THAT WOULD BE VERY NICE:-)
I have turned off everything except the body in question "Spindle", then saved it as a new doc. Then inserted that into my working doc. But even though everything else is turned off, I have the ghost of all those other bodies. Plus it must clutter up my project.
I even thought of exporting just the "Spindle" body, then re-importing? Step file?
Max
0 个赞
5,601 次查看
7 条回复
回复 (7)
2 条消息(共 8 条)
laughingcreek
@disneytoy wrote:
... I can't just copy and paste between documents....
news to me. guess I should stop doing it.
you can also right mouse click on just the component and export that into a separate file.  that can be inserted in a new document or drag and drop it from the data panel.  it will just have the features used for that component.  sometimes when things out side the component were referenced, the body will be converted to a base feature.
0 个赞
3 条消息(共 8 条)
jhackney1972
You forum question title and your actual question differ a bit.  In the title you ask about copying a component or a body.  In the actual question you only talk about copying a body, which is what my answer addresses.  Take a look at the Screencast for my process.  I believe the best way to copy a "body" from one design document to another is to use the "Insert Derive" command from the new design document.  Once the body is derived into the new design, you can break the link to make it a truly independent body in the new design.  You will have a choice of the amount of information you copy across which is shown in the Screencast.  One thing I failed to mention is that you can also derive body parameters into the new design document as well.  The option is at the very bottom of the Derive dialog box.
John Hackney, Retired
0 个赞
4 条消息(共 8 条)
disneytoy
Thank you, I will experiment with that. I mainly, as a beginner use bodies. I added component to my question, because I did not know if that made a difference regarding moving the object to a new file.
0 个赞
5 条消息(共 8 条)
TrippyLighting
4-5 years ago a common question on the forum was whether you can work with bodies only and if components were needed.
1. NO, in FUiosn 360 you cannot work with bodies only. Each Fusion 360 design file starts already as a component and that component can be used n other designs. Yes, within a file you can work with bodies only, but you insert that file into another design, it is a component. The symbol at the root of the browser is that of a component 😉
2. Is it advisable to work with bodies only?
It can be useful if you design single objects for 3D printing. If your design already involves more than one discrete piece, e,g. you have a box with a lid, you might want to consider using components.
This part of the Fusion 360 documentation explains the difference between bodies and components.
Here is a link to Fusion 360 R.U.L.E #1
You mentioned in this thread that you are "well versed in Fusion 360". I am having troubles consolidating that with the posts you make here on the Fusion 360 forum 😉
6 条消息(共 8 条)
disneytoy
Peter,
That is great answer, id that was my QUESTION.  I understand the difference between a body and a component. My question was simply bringing into a new Document, or Existing design, only a small part of an already designed part.
Obviously I can right click and INSERT the WHOLE file. But that often bogs down a design with the clutter of all the parts I don't need.
The person who suggested the Derive command seemed to understand better what I was asking. The ability to insert a portion of an existing document.
Max
0 个赞
7 条消息(共 8 条)
laughingcreek
just to re-cap:
-you can copy paste individual components (doesn't have to be the whole file)
-you can copy paste individual bodies (the caveat being you have to paste it into a base feature in the receiving file)
see screen cast.  Rectangle for a component copy.  Cylinder for body copy.
https://knowledge.autodesk.com/community/screencast/4a855b63-f70d-4b92-ab83-5a921cc8d5e6
8 条消息(共 8 条)
TrippyLighting
I'd like to add to what @laughingcreek and @jhackney1972 have said already.
1. the Save-as function saves an individual component or component group (assembly) from a design out into the data panel. That exported component does not have any links to the original design. To ensure that all the features, sketches, construction planes etc. come across into the exported file, make sure t stick religiously to R.U.L.E #1
2. To insert an existing component into a new one from the data panel there are 2 functions:
2.1 Insert into the current design. This will create a component linked to that design. One component can be linked into many designs. If you change the linked component, it will change in all designs it has been linked to.
2.2 Derive. You can derive one component from one design into another design. The Derive function can be very powerful and have unintended consequences. That's the reason I usually don't recommend it to new users.
Once a componet is derived into another design it can be altered in that design. However, the changes do not flow back to the original design.  However, if the component is changed in the original design, this will affect all derived instances of the componet.
If you want to re-use a componet in a new design and do not want to change it in that design it is better to use a linked component instead of a derived component.
