- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm continuing to draw an Adirondack chair to practice using Fusion. On the chair there are 4 brackets, all the same construction. They "belong" in 4 different places (the arms and backrest) - see photo - and ideally I want the Parts List to reference 4-off the bracket, rather than the bracket being part of the arm or backrest.
What I'm trying to establish is the best practice workflow making one body or component, then copying this into the right physical space. I've read that moving items isn't good, but I'm a little confused - is this bodies or components? I "think" that if I make a component, then move/copy it, I will get another instance of the same thing. If I then use the align command to get the part into the correct place, is that still a valid thing to do, or not "best practice"?
