Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
best method to join a square cut out with a circle cut out ?
3 REPLIES 3
3271 Views, 3 Replies
I am trying to figure out the best way to make smooth connection from a 40mm square pipe to a 51mm round pipe in fusion 360.
I am new to cad and fusion 360, so far enjoying but need to learn more advance stuff, if anyone has some good steps, best practices or pointers for this particulate problem, much appreciated.
Thanks much
Thanks much
3 REPLIES 3
PrecisionDesign
PrecisionDesign
Sounds like a loft feature should be used between 2 separate offset planes one containing the circle sketch and the other the square sketch.
Brandon
Brandon
laughingcreek
laughingcreek
"best" is always relative.  Here's a screen cast of the afford mentioned loft, along with a little playing around with the whole thing
in reply to: laughingcreek
Thanks that screen cast was excellent.
