Best approach for flower watering can?
WHolzwarth
Mentor Mentor
Message 1 of 45
WHolzwarth
Here' my wife's flower watering can. I tried it at first with F360 model environment (F3D attached), but then I didn't find a way for proceeding furthermore.
Therefore I converted to STEP and finished it with Inventor 2015.
I' ve had problems with an additional width loft for the front part, and bigger fillet radii at the rear. Selections for shelling in F360 seem to be tricky, too.
Comments welcome
Walter
Walter Holzwarth
Replies (44)
Message 2 of 45
jeff_strater
Thanks for the post, Walter.
I see some of the problems  you are having - it's tough to get the two fillets plus the shell to all work together.
When you imported this into Inventor, what values/settings did you use on the fillets and the shell?  And, what order did you apply the fillets?
I was able to get somewhat close, but it is clearly not the exact same model:
Jeff
Jeff Strater
Engineering Director
Message 3 of 45
WHolzwarth
Thanks for inspecting, Jeff. See my settings in Inventor 2015:
- Shell 2 mm
- Fillets mainly 4 mm
- Medium fillet of can outlet 4 mm, left and right 12 mm
- Fillets between can and handle 40 mm
I had to use some tricks in applying these 40 mm fillets. Face delete with healing didn't work all around the existing contours.
Shelling was tricky, too. Shelling the whole body did not succeed. I had to split into different bodies, shell each body for itself, and combine the whole thing again in the end. In the schreenshot I've marked the spot, that was causing the shell errors. Feature Browser in Inventor could have been much shorter, if I'd known that spot right after importing the STEP, but it's been some trial in finding it.
Walter
Inventor features.jpgWalter
Walter Holzwarth
Message 4 of 45
jeff_strater
Thanks, Walter.  Well, it's at least somewhat comforting that this was not easy in Inventor, either.  Yes, this is a bit of a complex model.
What were the steps in Inventor that you feel could not be duplicated in Fusion?  Is it just the fillets?  The splitting into multiple bodies for shelling should be similar.
If you want to share your Inventor model, I can take a look at that, as well, just to see whether some or all of those techniques could be done in Fusion.
Jeff
Jeff Strater
Message 5 of 45
WHolzwarth
Hi Jeff,
I've attached a 2nd attempt with F360. This time I've done the 40mm fillet at the handle at an early stage, before adding the smaller 4mm ones. But I'm stuck with the front outlet; a big problem seems to be no 3D lines in F360.
Even though I could get a patch by setting up an auxiliary sketch plane and line on it, but I couldn't see a method for mirroring this patch and adding it to the main body. After that an additional clean-up for the third front face would be needed, or perhaps sculpting would do the job.
I've tried shelling the back. Preview showed, but no result.
Inventor file is rather big, even with EOP pulled up. I'll try to clean it up, after knowing the problem zone. Where are the MB limits for attachments?
Smiley Wink But at first, it's time for several hours of lawn mowing ..
Walter
Walter Holzwarth
Message 6 of 45
WHolzwarth
Ok, I'm back with a new Inventor 2015 file, saved with EOP all up. For seeing the model, EOP needs to be moved down. Perhaps some time for re-build is needed, I didn't test it.
In the end, I could do my intended job with Inventor, but I had some new troubles. If other people can get the end result easier, don't hesitate with showing your way. I'm still learning ..
What can be seen?
- With F360, there seems to be no way for getting the end result
- With Inventor 2015, it seems rather tricky, too.
Conclusion for me: Both F360 and Inventor need better modeling tools.
Another conclusion: I for myself don't need these Cloud features at all. If other people appreciate them, it's ok. But please, leave me the way out  for working with my files and storing them on my own PC, without the time-consuming transfers to A360.
Later: I'm just trying EOP down, and Inventor seems hanging with too many features. I'll try now step by step. IMO, one more need for improvements.
More later: Meanwhile only 3 features are left in this rebuild. If there'll ever be a chance for a speed-up in the cloud, I'll think about it again.
Walter
Walter Holzwarth
Message 7 of 45
Thanks Walter for including the f3d files, I learned a lot from just going through scrubbing through each step of the timeline of your model.
Jesse
Message 8 of 45
WHolzwarth
Thanks back, Jesse
I'm no big Renderman, but see attached a picture, that's been done with Showcase 2015.
I've found a flower pot in Grabcad, and a HDR scene in Navisworks. Both could be combined with the watering can.
IMO, this is far beyond the rendering capabilities of F360.
If Autodesk really has made a decision for not further developing Showcase, then there seems some work to be done in other software.
Walter
Walter Holzwarth
Message 9 of 45
cekuhnen
I might suggest a different rounding strategy as well so you can prevent the undesirable side effect of the approach you used.
Check this file: http://a360.co/1AicNxz
Take a look at the image and pay attention at the side profile/edges of the vertical faces.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 10 of 45
WHolzwarth
Hmm. Surely I'm doing something wrong.
I'm trying to download a Fusion 360 Archive, I'm entering my E-Mail address, I'm getting a download link.
Clicking at this link results in a Zip.
Contents of the Zip is a file named Manifest.dat and a top folder named FusionAssetName[Active].
Smiley EmbarassedWhat has to be done now?
Walter Holzwarth
Message 11 of 45
cekuhnen
works here just tested it it only downloads the fusion file.
Here I added the file as a zip in the forum
Claas Kuhnen
Message 12 of 45
WHolzwarth
I could open the Zip attachment here.
Your approach is a different way of doing, but the problem zone with shelling seems to be the region, where the outlet is joining tangential to the main cone. Filleting outside can be done, but I had troubles with the shell. Strange to see, that shelling of my second attempt had issues on another zone.
Thanks for looking
Walter
Walter Holzwarth
Message 13 of 45
cekuhnen
I actually had the spout and handle added and shelling was fine. I then deleted those two so this file only has the side data
Claas Kuhnen
Message 14 of 45
cekuhnen
So here I rebuild the design for you from scratch.
http://a360.co/1zgUWvW
The only shelling/filleting problem I encountered was this edge:
So I rounded this edge after doing the shelling - not perfect but in this area doable.
So besides that one fillet related shelling problem the design tools in Fusion are sufficient to build somthing like this easily.
Claas Kuhnen
Message 15 of 45
WHolzwarth
It's looking good, but again I can't download the file. It's not only from your account.
Could you attach the F3D file here?
Walter
Walter Holzwarth
Message 16 of 45
cekuhnen
here is a link: https://drive.google.com/file/d/0Byzv_NlyKp_2U2VJcmhwbXYydWc/view?usp=sharing
Viel Spass
Claas Kuhnen
Message 17 of 45
WHolzwarth
Yes, I've found it already, after looking at your other topics around this task.
Meanwhile I've looked at your workflow. I think, a big difference is your sweep path for the outlet. It's not tangent to the cone.
IMO, if there's tangency, then it's some more difficult. What do you think, and can you show a solution for this situation, too?
Danke erstmal, Claas
Walter
Walter Holzwarth
Message 18 of 45
cekuhnen
I did not know this should be tangent - I just roughly rebuild the forms.
This would only require a spline for the left to be adjusted. Not a big deal.
Project the red line onto the spline sketch so you can match it easily.
Gern geschehen. Fusion ist schon nicht schlecht.
Claas Kuhnen
Message 19 of 45
WHolzwarth
Hmm. It's your file. Perhaps you're more accustomed with it.
Walter Holzwarth
Message 20 of 45
cekuhnen
here is the path tangent - however shelling bugs out here with 2 mm
https://drive.google.com/file/d/0Byzv_NlyKp_2ZFJKWGVlYmJpaG8/view?usp=sharing
Claas Kuhnen
