Bend a finished mesh or body along a line
Hello everybody,
I'm trying to make a cellphone case holder for my laser printer.
At the company where I work, we have GOM scanner, and already scanned the inside of the case.
The only problem is, that the case were a little twisted without the phone and so the mesh got that problem too.
Is there any option to correct that twist/bend?
I guess something to wrap the mesh around a guideline, or give it a plus helical vector maybe?
Here you can see the bending in the model:
Maybe somehow wrap aroud this line?
I'm looking forward to your answers!
Regards, Andras
Here is my file in case of need.
mango.freund
hello, there is no way, but with such simple shapes it is better to design a new volume body. scanning is okay, but not always the best. greetings mango
TrippyLighting
I completely agree with @mango.freund's post.
Also, Fusion 360 is a CAD software and as most CAD software goes not really the right software to perform modeling operations on Meshes.
TheCADWhisperer
I would use the scan only as reference (and calipers for measurements) in recreating proper geometry.
If you zoom in you will notice that there are no arcs, no curved faces - only straight lines and triangular planar surfaces.
Thank you guys for helping!
I thought there is a solution to work a bit less, but this is a solution to MY problem too!
