bend a body
bend a body
Message 1 of 12
bend a body
I'm relatively new to fusion 360. I downloaded a STL file from thingiverse that I am attempting to bend before 3D printing. I used the reduce tool to cut down the number of faces and then used the Mesh to BRep function to create a body, but don't know the best way to create a simple curve to the object. I am just a hobbyist trying to bend the handle of a toy for my kid. The part is about 1/2" thick, 6" long round handle. If there is a simple way to make a round object curve to follow a line, please let me know (in the simplest terms possible please)
Replies (11)
Message 2 of 12
jhackney1972
There is no Bend function for solid non-sheet metal bodies in Fusion 360.  If you create a sheet metal body, you can use the Bend command.  Since you are coming from a STL file I doubt you can convert it to sheet metal to use this tool.  It would be best just to model the component and sketch in the bend you need.  If you attach your model the forum users can probably give you a hand.  If you do not know how to attach your Fusion 360 model, simply open it in Fusion 360, select the File menu, select Export and place the file on you hard drive.  Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Message 3 of 12
g-andresen
Show what your body looks like now, share your design and tell us what it should look like in the end.
günther
Message 4 of 12
mitchellforrest46
if you guys have figured this out i would love to know i have exhusted every option i know of. i will post my mesh if you guys are able to help
Message 5 of 12
jhackney1972
The forum users need your Fusion 360 model.  If you only have an STL file, then attach it.  There are ways to bend solid models but we really need to see the file to tell you how to do it, if possible.  If you do not know how to attach your model, open it in Fusion360, select the File menu and then choose Export and save the .F3D file to your hard drive. Then use the Attachments section of a reply forum post to attach it.  If you have trouble attaching it, zip it first.
Message 6 of 12
mitchellforrest46
It will not allow me to attach file it says its to big. This being said there must be a simple way to make this very simple action happen. All I wish to do is take an image and bend it to a slight curve
Message 7 of 12
davebYYPCU
Not in Fusion,
you make the item (bent) as you need it.
Maybe sheetmetal but we cant see it.
Might help....
Message 8 of 12
mitchellforrest46
Well that’s why im asking how to do so and I cant send it over email its to big
So if you could instruct me how to do so It would be much apprchiated
Message 9 of 12
laughingcreek
If you all you have is a .stl file, then fusion is most likely the wrong tool.  A mesh editing software like mesh mixer is more likely to work.  if you made it in fusion, then export the .f3d file and attach that.
even pictures help with understanding more than nuthin
Message 10 of 12
mitchellforrest46
I have meshmixer but I don’t seem to be able to do so, any tips? I will try to make it a jpg to share or something. Its a free stl from turbo squid
Message 11 of 12
laughingcreek
there is a forum for mesh mixer where folks will help.  one thing that can help when doing transforms on meshes is to remesh it sp most of the faces are about the same size, instead of the jumble of big long triangles and a gazillion little triangles that most cad packages output.
most operating systems have a screen capture tool that come with it.
Message 12 of 12
hfcandrew
The tool in Meshmixer is called 'Warp':
http://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-7E271E0A-E771-4C87-85F9-9D3FC63AC5B9
Here is a video of what you can do with it:
https://autode.sk/39wy27t
Please make a post in the Meshmixer forum (it's annoyingly hidden because it is grouped in under Netfabb):
https://forums.autodesk.com/t5/netfabb/ct-p/980
