Belt assembly
10 REPLIES 10
Message 1 of 11
5281 Views, 10 Replies
Belt assembly
Tell me how to make timing belt and the rotation of the two pulleys? I found on YouTube instructions for Inventor, but they do not work for Fusion. Maybe there is a suitable screencast?
For example, the chain and the sprocket is also interesting
10 REPLIES 10
Message 2 of 11
innovatenate
You can get two component to rotate with a relationship or ratio defined in a command called Motion Link.
There's a really old video in the below link, but the basic idea is the same.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/CloudHelp/cloudhelp/ENU/Fusion-...
I hope that helps, let us know if you have any questions.
Nathan Chandler
Principal Specialist
Message 3 of 11
in reply to: innovatenate
Of course there are issues!) How to make to rotate not only the gears, but the belt \ chain? There are many instructions on how to do it in Inventor. Is it not possible to fusion? I really need a belt drive, and I do not want to download  Inventor for it
Message 4 of 11
innovatenate
There's not anything that really comes to mind to get a belt or chain to move with the pulleys at the moment.
You may consider adding a feature request in the Fusion 360 Ideastation for future consideration:
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/idb-p/125
Nathan Chandler
Message 5 of 11
O.Tan
Make an idea station request and you'll get my vote on this!
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Message 6 of 11
carl_bass
in reply to: O.Tan
You'll get my vote too. Being able to model gears, chains, pulleys easily with the right behavior is really important
Message 7 of 11
burnandreturn
in reply to: O.Tan
You will get my vote also if you do this in the idea station.
Message 8 of 11
in reply to: burnandreturn
I want to ask all of you to formulate the idea to write because I do not write very well in English
Message 9 of 11
innovatenate
I have posted an Idea on your behalf in the below URL. Please Vote it up!
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/drive-components-belts-amp-pulleys-or...
Feel free to leave any additional comments if I've missed anything!
Nathan Chandler
Message 10 of 11
This Idea is labeled as solved, is there any application in fusion yet? I am trying to model something with a belt today and cant find any information beside this post.
Message 11 of 11
paul.clauss
Hi @Anonymous
This thread was marked as solved because Nate confirmed that a belt tool is not yet available in Fusion 360. He also created an Ideastation post requesting this feature to be added, which is being considered for future implementation. Please give the idea a vote if you would like to see belt assembly tools included in Fusion 360!
Feel free to let me know if you have any questions!
Paul Clauss
Product Support Specialist
