Beginner here. Adding a dimension symbol in a linear dimension
knightersunit345
Message 1 of 11
knightersunit345
So I am trying to add a diameter symbol to a dimension and I saw that need to add "%%c" to the dimension text IPE.
1. Could someone explain what the dimension text IPE is? I have read several forums about it but I still don't understand.
2. Where is the dimension text do I add the %%c? Is it before or after "29.41" or after the "mm"?
Any help is appreciated.
Replies (10)
Message 2 of 11
jhackney1972
Normally you do not have to use the character symbol string to get a diameter symbol, it is placed automatically.  If you are dimensioning something that is not a diameter, heavens knows what, you can use the %%c in front of the text according to ANSI drafting standards.  Take a look at the Screencast.
John Hackney, Retired
Message 3 of 11
knightersunit345
So this is what Im trying to do(see highlighted dimension). How did this person do this? How do I do this?
Message 4 of 11
davebYYPCU
Edit Sketch
Start Dimension
Select centre line and then outside line, before placing the dimension on the screen,
Right Mouse Click, select Diametre Dimension,
place the dimension and create value.
Might help....
Message 5 of 11
rohit.bapat
Hello @davebYYPCU
Just a minor update. While adding the dimension, with new centerline type, whenever user selects one centerline and a parallel line or a point we automatically switch to diameter dimension.
Thank you,
Rohit Bapat
Rohit Bapat
Product Owner
Message 6 of 11
davebYYPCU
Ok, thank you for that,
He is not using a Centre line style line for his question, - I'll presume the old way still applies.
Message 7 of 11
rohit.bapat
Hello @davebYYPCU
Yes, old way to add diameter dimension is still available.
Thank you
Rohit
Rohit Bapat
Product Owner
Message 8 of 11
shahriarsifat1802164
You need to make a reference line for this.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 9 of 11
here is a screencast
RUET
Thank you.
Message 10 of 11
Centerline dimension | Fusion 360 | Autodesk Knowledge Network
RUET
Thank you.
Message 11 of 11
here
RUET
Thank you.
