Basic Sketch question - How do I sketch a line NOT a tangent arc?
RandyKopf
RandyKopf
Such a basic thing
I have a sketch with some lines that are not connected
I want to sketch another line to join them.
The system seems to want to default to drawing a tangent arc at the end of a line I select.
Is there a hot key to NOT use tangent arc? Or simply force LINES only.
Thank you!
Randy Kopf
http://desktopartisan.blogspot.com/
If my post is helpful, press the LIKE Button If it resolves your issue, press Accept as Solution! Have a great day!
TheCADWhisperer
Click-click, not click and drag.
g-andresen
Hi Randy,
Left click and hold during movement creates an arc with tangential connection.
Left click (without hold) creates a straight line.
günther
RandyKopf
Thank you @g-andresen I appreciate you taking the time to explain that. As silly as that was it took extra steps to compensate haha Randy
Randy Kopf
