Basic Drafting Issues
Hi  I have submitted part of this concern to support but have found to many issues beyond the one that I submitted.
When doing a medium difficulty drawing I have found numerous problems that I hope someone else has seen.
Create a center-line through a angled hole - cannot select the 2nd edge (this one is weird, I need a new model to confirm repeat-ability)
Cannot dimension a line to a point
Cannot create an aligned view to a feature - like a hole on an angle to it can be located
Dimensions do not stay associated to the feature, edge or end point when model is modified
Cannot apply a dimension to intersections of center-lines that do not loose association immediately
I will provide a screencast later tonight when I have a moment to create a model to demonstrate the issues.
robduarte
Screencasts are helpful. You'll probably have better luck getting answers if you post each problem separately. It's also useful for people who have the same/similar problem in the future since you can mark an answer as a "solution".
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
