Basic design issue.
Basic design issue.
hato54
Basic design issue.
hato54
I'm very intrested to use Fusion 360 but some times I get lost in basic features. (Now I have 15 daysleft before time limit)
Normally I use SolidWorks and directly put the dimensions when I create a body.
But how do I do that in Fusion 360? (in sketch mode it's easy)
If I have a part and like to make a hole and a square on the body, I do that but how do I place or move the hole in exact position regarding to a specific position (corner,center...)?
hato54
OK, I find it. "Edit-References"
michallach81
Hello, in order to be able to move "feauters" that are "Joint", "Cut" or "Intersect" with "Body", you have to create them from sketch, by "Press Pull" (under "Modify" tab), or "Extrude", "Revolve" etc. (under "Create" tab). That creates sketch "feautre" and you can move geometry in sketch, by "Move" command (select an obcject (LMB), then press RMB and menu will appear with "Move" command, select it), or by applying constraints, like "Sketch Dimension" (under "Sketch" tab, just above constraints). "Move" command allow you to use Manipulator to drag object or specify points to move object (from/to).
All that is true if history record is enabled (and that is a default setting, you should see a ribbon at the bottom of your screen), other way to move those feauters that are combine with main body is to stop record history, and in direct moddeling enviromet you can pick previously created feautre, it will be extrude or revolve, and you can use "Move" command , no sketches are needed.
Sound complicated, Fusion have to modes to work with, one that capture history and second without just direct moddeling (please check some learning resources in example : http://help.autodesk.com/view/NINVFUS/ENU/?guid=GUID-856A6ECE-D4D9-4FBA-B8C6-3F1151C973B2). Tools behave differently in each mode, they creates different feauters in feature tree.
Simply, in direct enviroment you can use "Box", "Cylinder" and other tools from Create tab, just watch what feauter will appear in your tree, you can move it easily. If you like to stay in enviroment with history use a sketch to create new geometry (and that only if that geometry will be combine with some already existing geometry. If you select to make separate object, you can use those features from Create tab, and move them afterwards).
Sorry for my bad english.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
hato54
Hi
Yes I also think that's a good idea to work in sketch mode. That's more like SolidWorks.
Thank You for helping me, I'll take the next step (tomorrow)
Regards
Håkan
prabakarm
Hato,
For holes, we do support referencing model edges and faces to position the hole.  For other geometry creation commands sketch is the basis and lets you manipulate the geoemetry and position.  You can also create seperate bodies of your geometry and use the move, align commands to position the body and the combine command to add or remove material.
We would be happy to support you thru these forums as you try to use Fusion 360.  Let us know how we can help.  I would also encourage you to take a look at our new onboarding content as you work your way thru Fusion 360 if you have not already.
http://forums.autodesk.com/t5/general-fusion-360-questions/get-fusion-360-training/td-p/5424704
Prabakar.
