Ball Joints - Back to Basics
glassjoe
glassjoe
I'm new to joints and confused about the apparently missing Y axis of the ball joint. I've read a couple of posts that go into the theory behind the ball joint, I appreciate it's a complex issue but I'm hoping someone can show by way of example simply how to use it. In the attached model, how do I rotate the joystick around the Y axis (left to right in the FRONT view)
thanks for your consideration,
Joe.
jhackney1972
A Ball Joint only has 3 rotation degrees of freedom and the way you had the original joint positioned does not allow for the motion you asked for.  The Screencast will show you how to re-position the Ball Joint and how to lock the axis you do not need to get just the motion you desire.  Model is attached and I left the wireframe on.
John Hackney, Retired
hamid.sh.
Firstly, please always make your sketches fully constrained. Secondly, what you made is already correct. You only need to Ground the block. Now because this joint has 3 axes of rotation it's hard to rotate it around one axis without touching others. To visualize this I added a dummy component and a planar joint, you can play with it and see your current joint DOES rotate around Y-axis of assembly (this I added ONLY for visualizing, you don't need this planar joint at all. Suppress it later).
Now if you want to rotate around Y with your original model; usually you can use Drive Joints to achieve this but at current position Yaw axis is not aligned along Y-axis of origin. You have to first align it by adjusting Pitch and Roll:
Hamid
glassjoe
@jhackney1972 @hamid.sh. thank you both for your great (and varied) solutions to this - i've tried both and had success. I'll need to give some more thought to why they work, I can't say that F360 is entirely intuitive in this respect but I'm glad to have a fix. cheers!
