baffled by import image
fritter63
Message 1 of 30
fritter63
I've been playing around importing images so they can be traced. I'm confused at what ends up getting imported.
See attached picture. When I import an image, I get a "squished" version of it, the aspect ratio is not maintained from the original image.
However, if I try to scale it by doing the aspect ratio math (in this case 2016/1512 = 1.333), the image does not go back to what it should be. The scale actually needs to be more like 1.6. What am I missing here? Why doesn't it not maintain the original aspect ratio?
Also, is there any plans to add ability to import eps files or such that will get the tracing done automatically?
Thanks.
Distorted and original attached.
Replies (29)
Message 21 of 30
TrippyLighting
@fritter63 If you had done some research and come across this, I wonder if you had still posted that offensive nonsense!
Message 22 of 30
fritter63
@TrippyLighting Ouch. Thanks for the update. Too much to keep track of these days.
Sorry if you were offended. 🙂
Message 23 of 30
servispcnachod
Community Visitor
Community Visitor
Hello all, its 2025 now and bug is still there, using picture taken by my iPhone 13 as canvas in Windows 11 computer (core i9 14900k/rtx3090/64GB). For simple solution ive found this workaround. Just convert your image as any uncompressed bitmap, such is *.bmp to get rid of exif information, and then back to jpg. Your new jpg will be ok, without distortion. Just dont understand, why Autodesk, creating such wonderfull software, simply ignore it for such long.
Have a nice day.
Message 24 of 30
srick79
Observer
Observer
Cropping 100% fixes the issue. What a stupid import bug.
Message 25 of 30
srick79
Observer
Observer
Cropping 100% fixes how it import for me. I never had to do this before.
Message 26 of 30
samkemp1996
How is this still not fixed???
Message 27 of 30
TrippyLighting
It was fixed in a recent update... after almost 10 years 😉
Message 29 of 30
max-k83
Community Visitor
Community Visitor
Not fixed at 17.08.2025, the mentioned before workaround is to rotate before inserting.
Message 30 of 30
david_gillblom
Community Visitor
Community Visitor
I then need to rotate it back once in Fusion. Annoying, Autodesk plz fix
