Bad quality of a guide (rail)
Hrvoje-
Hrvoje-
Hi!
I am trying to loft along the rail several profile lines. The rail has the error, but I can not see it, even at the maximum zoom. I do not know how to correct these errors and finish the lofting. It says not G1 (tangent).
I attached the Fusion file with the problem.
Thank you for the help. 🙂
The rail with errorsThe rail with errorsThe hull form I am trying to obtainThe hull form I am trying to obtain
Is this OK?Is this OK?
Kind regards,
Hrvoje 🙂
TheCADWhisperer
I would strive to fully define each and every sketch element as it is created.
I would strive to simplify sketches.
If I drag the arc that you circled in red - I see that the endpoint of the arc is not coincident to the endpoint of the line. (See image below.)
Hrvoje-
Thank you for the answer! In accordance with your advice I deleted all not necessary for the lofting of a ship's hull. It makes the situation more clear. I found one error and there is at least one undiscovered. 🙂
Kind regards,
Hrvoje 🙂
