Backups of edited files in trash folder.
HughesTooling
Consultant Consultant
HughesTooling
I'm not sure if this should go here or in the Fusion CAM form.
Fusion can save it's tool libraries in 360 Drive, in the past after any edits the old version was saved\moved to the trash folder. This came in handy a few times when Fusion decided to delete all the info it saved on 360 drive for no reason.
Fusion recently had another bug that deleted the tool libraries but looking in the trash it looks like no backups have been saves after 3 Sep 2015 has something changed and is there any way to specify which folders and file types are backed up in to the trash folder?
Mark
Mark Hughes
Owner, Hughes Tooling
Bud_Schroeder_ADESK
Hi Mark,
Thanks for the post, and yes it should go in the Fusion Forum.  I'll go ahead and move this for you.
Thanks for all the details, it will help the team.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
HughesTooling
@Bud_Schroeder_ADESK To me this seems more a 360 drive problem than a Fusion problem. The folders and files are on 360 Drive not A360 so it seems 360 Drive is what's monitoring what's going on in it's folders and should be making the backups.
I'll make another post in the CAM forum as well because only the CAM uses 360 Drive.
Mark
Mark Hughes
HughesTooling
I got an answer to this here.
Mark
Mark Hughes
fulcrumusa
I wish the response elaborated on how they actually do the update-in-place. Depending on the algorithm used, update-in-place can end up completely and unreversably screwing up your data.
