Axis to axis transformation
novakLT3XW
novakLT3XW
In European Automotive,  all parts are drawn in position in car, so manufacturer does not need to transfer part every time designer modify something. All tools, gauges and similar are drawn in position around part in car...
In fusion is pain even to create axis system (I did not found other solution than create component inside component and use its axis system by moving this inside component).
Now the problem is - When other customer/supplier use basic axis system, how I can transform this to get it to part in car axis system? In catia, SolidWorks and similar software, there is simple single icon and transformation is done.
I found similar issue, which has been arcvhived, because only 2 people voted. I guess thousands others just use different software, because other than axis to axis transformation is pure pain.
Archived issue:
https://forums.autodesk.com/t5/fusion-360-ideastation-archived/axis-to-axis-transformation-and-wiref...
Will this ever change?
mango.freund
hello - yes with fusion you have to rethink something. everything is constructed on site as it will be finished. but be careful, all components are then connected with joints and fixed in place. there are tons of joints to mess around with. BR mango
