automatically calculate the spacing of points on a curved surface
hello,
Hope you can help me on this one,
I have a curved shape with slots spaced regularly by 2,7mm on the outer shell of this shape.
I would like to figure out what is the spacing of every slot on the inside of the shell
As you can immagine, due to the odd shape, every slot has a different spacing on the inside :
What would be you strategy to automatically measure and ultimately create a flat pattern sketch of the inside shell ?
Thanks a lot
Thomas
PS : this topic is for calculating stitch spacing on a leather gusset project.
g-andresen
without seeing the design, I can only say that due to the changing radii, even the distances on the inside cannot be constant.
But share the design to look more closely.
günther
sure thing,
@g-andresen you are right, I should have include the file on my previous post.
Thanks a lot for your help,
Thomas
TrippyLighting
Quick question:
You do realize that your spline is not symmetric across the Z -Axis and that offsetting a spine breaks the curvature?
Hi, @TrippyLighting
Yes I did...And i couldn't figure out how to fix it 🤔
I mirrored the spline handles, but still...
@TrippyLighting OK I managed to repair the sketch
please find attached the updated file.
Thanks a lot
