Autodesk CAD Benchmarks
mcramblet
Message 1 of 11
mcramblet
I need to gather some data to create a ROI on a more robust workstation. I'm aware of some of the generic ones, such as what is listed here:
http://blog.grabcad.com/blog/2016/03/16/benchmarks-cad-workstation/
I'm wondering if Autodesk has and/or could recommend some benchmark tests that would most closely relate to Fusion 360 performance (both CPU and GPU). I'd like to see if I can have the vendor run a benchmark on the machine I'm looking at, so I can compare it to my current one. I'd like to narrow things down, so I don't have to ask for a bunch of different benchmarks. Any recommendations?
Replies (10)
Message 2 of 11
mcramblet
Unless there is other information, it looks like this may be the best bet:
SPECviewperf® 12
SPECviewperf 12 is the worldwide standard for measuring graphics performance based on professional applications. The latest version is SPECviewperf 12.0.2, which extends performance measurement from physical to virtualized workstations. SPECgpc members at the time of V12.0.2 release include AMD, Dell, Fujitsu, HP, Intel, Lenovo, Micron and NVIDIA.
SPECviewperf 12 measures the 3D graphics performance of systems running under the OpenGL and Direct X application programming interfaces. The benchmark’s workloads, called viewsets, represent graphics content and behavior from actual applications.
Message 3 of 11
brianrepp
@mcramblet - I don't believe that I've ever seen any public benchmarks, but have reached out to a few others on the team to see if they have any.
Message 4 of 11
mcramblet
@brianrepp, that would be great, thanks. The SPECviewperf was just for video performance, so I'll also try the SPECwpc benchmark. If something else turnes up that would be a better benchmark option, all the better.
Message 5 of 11
baribak
Are you looking for the types of operations in Fusion to execute as part of this? e.g. loading large files, computing complicated timelines, large xref files, etc.
Kevin Baribault
Fusion 360 Quality Assurance
Message 6 of 11
mcramblet
Yes, if something like that already existed, that would be great. I'm not sure that I'd be able to convince the vendor to run any tests for me, after all. Even if I can't, I'd still be interested in running the benchmarks, myself, after the fact.
Message 7 of 11
I_Forge_KC
Perhaps you could work with the creator behind the benchmarking tool for Inventor called Inventor Bench. The API in Fusion isn't nearly as exposed/capable as in Inventor to enable some of the features, but the methods of testing may be of some use to whoever works on such a tool.
Just a thought, really.
K. Cornett
Generative Design Consultant / Trainer
Message 8 of 11
baribak
Additionally, here are some operations you can track with regards to CPU speed, etc.:
Load files of different sizes and complexity:
  • DM designs
  • PM designs
Load files of different types:
  • Base design
  • Simple xref design
  • Large xref
Cold Open (Fusion launched, open design)
Warm open (Fusion already running, open design)
Compute Performance
  • Small files
  • Large files
  • Xref files
Sketch operations
Local Sim Solve
Local Render
Local Create Toolpath
Kevin Baribault
Message 9 of 11
stiller.design
Benchmarks would be great... I'd loved to know how the new AMD CPU compare to the Intel CPU's.
Also that AMD has a lower single core clock but higher IPC
And regarding GPU it would be VERY GOOD to see what a good card. Apparently Quaddros and Firepro are not fully supported but there is no documentation at all. So setting up a new system is complettly a guessing game 😕
Message 10 of 11
daniel_lyall
See if this helps you https://www.youtube.com/watch?v=JCSddpLk9H4
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 11 of 11
stiller.design
that very interesting !!!!
still I would like to know more from Autodesk:
what works better cheap gaming card or a professional graphic card (looks like its the gaming card, but I am guessing)
