Auger flight flat pattern
benzlerW44MW
Message 1 of 10
benzlerW44MW
Hi guys,
First post here. Please be gentle.
I am trying to convert from Inventor to Fusion and now I am stuck at creating a flat pattern for a screw conveyor auger. I can draw it similar to how I did it in Inventor - by creating a surface loft between two coils (instead of spirals) and thicken it but when I try to convert into sheet metal it fails. Fusion "can't calculate body thickness".
Any advise? Screenshot from Inventor below.
Edit: attached Fusion design
Replies (9)
Message 2 of 10
g-andresen
please share your design.
günther
Message 3 of 10
benzlerW44MW
Hi, added design now.
Message 4 of 10
g-andresen
Where?
günther
Message 5 of 10
lichtzeichenanlage
1st post
Message 6 of 10
benzlerW44MW
It's attached under the inventor image. Attaching it here as well.
Message 7 of 10
Beyondforce
Hey @benzlerW44MW ,
I hope this will help you:
https://knowledge.autodesk.com/community/screencast/ccbf9032-2e36-42bd-9d33-42a4c9e628bf
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Need a new computer? Fusion 360 Hardware Benchmark: TESREG.com
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
| YouTube
Message 8 of 10
davebYYPCU
Did you read the question?  I watched to the end, maybe you have 2 videos?
Maybe the next one for the answer? please.
Message 9 of 10
Beyondforce
Yep, it was my mistake!
I have checked the sheet metal issue, and I couldn't do it as well. So I tried another twisted shape and it didn't either, so I'm guessing it's either a bug or a limitation.
Ben Korez
| YouTube
Message 10 of 10
davebYYPCU
Slept on the problem, overnight I remembered this one,
Meshmixer fix
Message 2, will get you there, I think.
Edit; Worked for me, tip - extrude the plate in Mesh Mixer, so the there is thickness to section with fit curves to section back in Fusion....
Might help....
