No matter what I do ( different files, restarting fusion) my controls for canvas on one plane are broken
See screencast
See screencast
Yeah, that looks like a bug. I'll report it and get it fixed. It looks like it is only the YZ origin plane that has this problem - the rest seem to behave OK.
Jeff Strater (Fusion development)
the problem is not only that, on a mac when you attach a canvas or try to ad a decal ig et very strange black image and all colour do strange things.
BUT no image as a result.
i have not tried it yet on a pc.
Hi, This is a known issue we observed on few specific Mac machines and we are working on the fixes right now. One potential workaround is when you run the decal command, don't pre-select any face; instead first select the texture, and then select the face. You may try it on your side to see if it works.
Chengyun
Chengyun
this works. super thanks
This workaround works for me also (selecting image before selecting face).
thanks a lot
@chengyun.yang wrote:Hi, This is a known issue we observed on few specific Mac machines and we are working on the fixes right now. One potential workaround is when you run the decal command, don't pre-select any face; instead first select the texture, and then select the face. You may try it on your side to see if it works.
Chengyun
thanks a lot
Chengyun
This bug will be fixed in the July 27th release.
Colin
Colin
