Asymmetric fillet
Asymmetric fillet
ManikantaAthukuri
Message 1 of 12
Asymmetric fillet
ManikantaAthukuri
How can we assign an asymmetric fillet in Fusion 360?
Eg: Assigning a fillet on the inner edge of a cube for which one side is 10mm and the other side 5mm.
Please do provide a solution if you know
Manikanta Athukuri
Replies (11)
Message 2 of 12
jeff_strater
use a Variable Radius Fillet
Jeff Strater
Engineering Director
Message 3 of 12
jhackney1972
Either I do not understand your question or you did not make it clear enough.  The Screencast shows what I read in your question.
John Hackney, Retired
Message 4 of 12
TrippyLighting
Manually by sketching a curve or ellipse and extruding the resulting profile:
Message 5 of 12
jhackney1972
@TrippyLighting@jeff_strater  Three different answers to an "unclear" question!
Message 6 of 12
davebYYPCU
At least your inside, my mind has inside floor fillet, 10mm and 5 mm at the mitre, if so that makes 4 versions, but he has 3 more mitres to tell us about.
There was a tutorial on the corner handling, but don’t remember it now.
Message 7 of 12
TrippyLighting
Yep, that would be another interpretation responding to the "inner edge" of a cube.
Alas, a cube does not have an inner edge ?
Message 8 of 12
davebYYPCU
Yup.
Message 9 of 12
TheCADWhisperer
Cube
Fillet 10
Shell 5
Done!
Message 10 of 12
ManikantaAthukuri
@TrippyLighting @jhackney1972 @davebYYPCU @jeff_strater @TheCADWhisperer
Sorry, my question is not clear. I thought that the analogy is clear.
However, here is the exact problem.
I will be clear from next. Thanks for the solutions you have provided even though the question isn't clear.
How can we obtain a fillet as shown in the figure?
Manikanta Athukuri
Message 11 of 12
davebYYPCU
That will be same as Trippy's answer,
draw the profile, and sweep it on the edge, as build for inside edges (or cut material for outside edges).
Need a Sweep Path to attach the sketch (SP point) to
Might help....
Message 12 of 12
JamieGilchrist
Hey @ManikantaAthukuri,
The good news is that the team is working on this currently. We will initially only support tangent boundary conditions. I don't have a specific timeframe when this will deliver, but it is being worked on.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
