Assembly relations not kept when project is copied
Message 1 of 1
I'm a new fusion user making an assembly at my job using the workflow described by Rob Cohee which uses the new edit in place function (https://www.youtube.com/watch?v=yPZkYSlT6FA&ab_channel=AutodeskFusion360). The workflow has worked extremely well for our application but when I used the Fusion Team website to copy the project many of the assembly contexts broke. For cooperation purposes, the main assembly consist of 2 "sub-assemblies" and then the sub-assemblies themselves contains the parts/components. In the copied project the changes made with edit in place in the main assembly do not change the parts contained in the sub-assembly, whereas they do in the original project.
The worktree in the bottom does indicate that the assembly context has been broken but I'm not sure how to fix it.
Replies (0)
