Assembly - follow path
Is it possible to have a cylindrical component follow a curved guide in Fusion 360 other than using contact sets? See attached screenshot.
Thankful for any answers.
jeff_strater
you can try it with contact sets.  If your overall design is more complex than in that image, though, it is probably not going to work all that well - contact sets is very slow to compute.
Outside of contact sets, there is no great way to define this motion currently.  We are working on a solution that will help with this kind of joint, but unfortunately, it is not yet available.
Jeff Strater
Engineering Director
mango.freund
hi @Anonymous , make too slide joints one about the other in 90 degree
mango
TrippyLighting
That will not create a motion of that small wheel along the curve/
A planar-motion joint with contact sets enabled worked fine for my application. I just needed to simulate the motion of a tilting gate for my Roomba garage project.
Thanks for your suggestions
