Assembly Feature
Assembly Feature
Assembly Feature
Hey all.
I'm working on a Nicholson workbench design and I'm adding the finishing touches:
I've got a four leg assemblies, three of which are the same and one which is the same of the others but which needs a hole cut for the vise guide:
Is there a way to create an "assembly feature" with a rectangular hole just through this one leg? This is how I would build the thing.
chris
I think Right now there is no a "Feature Assembly", but you can try with copy a Leg component and "Paste New" and then Make the hole in the new one.
Gilmer J. Vizconde
If it was useful please mark as a solution and give me kudos  Smiley Wink
cekuhnen
@Anonymous @Anonymous
Ah why dont you use solid combine to cut the space out by a sketch that uses the same dimension (find sketch through intersection of model through sketch plane)?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
This works, but the cut is applied to all the instances of the leg pieces.  Not really what I want.
TrippyLighting
Correct! None of the replies address that, but it can actually be done.  I made a video a few weeks (embedded below) that explains the fundamental of how to do this.
Also, the handout I prepared for the class I co-hosted  at Autodesk University has a section on (feature) configurations and applies directly to this problem and provides the solution.
In short, instead of copy/pasting a component, create an empty component for the leg  and then copy/paste the body from the other leg into it. Then you can add that cutout to just that component.
If all that is too abstract and long winded you could also just share your design and I'll show you.
Sorry been up to my nether regions in reptiles and haven't had a chance to do a lookie see at this.  Will let you know
cheers
chris
