Assembly Context loses associativity after Save As
Hi all,
I'm having an issue with Assembly Contexts. My use case is this:
I make template models of complex cabinets, usually with several other nested components that are also from templates (example: a door or drawer box with Associativity for size, etc.). Then, I insert those cabinets into an assembly model, which contains a sketch or other geometry to drive the sizes of those cabinets using Assembly Contexts. Once I've inserted and associated those cabinet components, I will then "Save as and Replace" so that the cabinet is now unique and my template model stays intact.
By doing this, I should be able to make changes to the assembly model driving sketch and see those changes perpetuate throughout the design. This works for the top level association (ie the cabinet size). The problem is, those nested components (ie the doors and drawers) remain associated with the original template model, and so I can't update their Assembly Contexts.
Is there a workaround here, besides breaking the links to all the child components?
I recreated it in this screencast--hopefully it makes sense.
Thank you!
