We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Assembling a square cylinder into a square hole.
lemelman
Message 1 of 14
lemelman
I've modelled an odd shaped torus containing a square hole and need to assemble a same-sized square rod into it. I understand (I think) how to assemble a round rod into a round hole, but the square hole has me beat. None of the edges of the hole are in the same plane - see the attached screenshot. Can you help please?
Replies (13)
Message 2 of 14
Beyondforce
Hi @lemelman,
You can use the Joint Origen. Check out this video on how to use it: https://www.youtube.com/watch?v=OsVz2XjVduc
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 14
TrippyLighting
Please share your model. Export it as a .f3d file and attach it to your next post.
Message 4 of 14
lemelman
I've attached a .f3d file of the torus and a cube that fits inside. It's actually the complete model I created, but with only the torus and cube "switched on". The rest of the drawing, which I hope is not visible, consists of various unsuccessful attempts to fit the cube into torus.
Message 5 of 14
lemelman
Hi Ben,
Sorry, I can't see how the "joint origin" helps. In the CAD program that I used to use I can assemble by 3 points, but I can't see a way to orient the torus and cylinder in Fusion.
Message 6 of 14
Beyondforce
Is that what are you are trying to accomplish?
Cheers / Ben
Ben Korez
| YouTube
Message 7 of 14
lemelman
No, the cube has to fit inside the square hole in the torus, like in the attached screenshot.
I spent ages fitting it by hand,making lots of tiny adjustments, but its not precise. I want a way to make Fusion do it exactly.
Message 8 of 14
Beyondforce
Check out the attached file.
Cheers / Ben
Ben Korez
| YouTube
Message 9 of 14
lemelman
Hi Ben,
The file won't open on my system; I get the attached error window. Does the file tell how you did it?
Message 10 of 14
Beyondforce
Hi @lemelman,
You get the error, because you need to Upload the file first, then you'll be able to open it.
Here is a screencast of how I did it:
Cheers / Ben
Ben Korez
| YouTube
Message 11 of 14
lemelman
Thanks Ben, that does it nicely. Thanks also for the tip about Uploading.
In this particular instance, it wasn't possible to build the cube in place because of the other things I needed in the final model, which determined the order I did things. Had I known the difficulty I encountered in doing the alignment (trivial in my previous CAD program) then I would have done things differently.
Message 12 of 14
Beyondforce
Here you go:
Cheers / Ben
Ben Korez
| YouTube
Message 13 of 14
lemelman
Thanks again. I'm slowly getting there but unlearning is a difficult process.
Message 14 of 14
Beyondforce
Anything you need, just let us know.
There are no stupid questions only stupid answers! 😉
Ben.
Ben Korez
| YouTube
