@jrogers80
Jimmy, always best if you can upload your file so it can be checked as an image doesn`t tell anybody what you have/haven`t done, go to File>Export>Save as f3d format to your computer and then attach it to your next post.
Meanwile I have done a small example for you to try out, you can select the Circular Pattern from the Timeline and Edit it and have a play doing different numbers of Fillets. The Fillet has to be a "Stand alone" Body, it can be joined to the main Body later after the Pattern is done and make sure you have the Axis correct that you are doing the Pattern around, in the attached example I created everything on the Z axis centre.
Without a file to work with this is all I have for now 🙂
Regards
Rob
