array this feature
array this feature
jrogers80
Message 1 of 9
array this feature
jrogers80
I can not array this gusset in a circular pattern. I know there is something that i am missing or have done incorrectly. Can anyone help me out?
Replies (8)
Message 2 of 9
engineguy
@jrogers80
Jimmy, always best if you can upload your file so it can be checked as an image doesn`t tell anybody what you have/haven`t done, go to File>Export>Save as f3d format to your computer and then attach it to your next post.
Meanwile I have done a small example for you to try out, you can select the Circular Pattern from the Timeline and Edit it and have a play doing different numbers of Fillets. The Fillet has to be a "Stand alone" Body, it can be joined to the main Body later after the Pattern is done and make sure you have the Axis correct that you are doing the Pattern around, in the attached example I created everything on the Z axis centre.
Without a file to work with this is all I have for now 🙂
Regards
Rob
Message 3 of 9
jrogers80
thank you for your reply, here is the file. when i array this gusset, it looks like it has a placed the 10 gussets around the part but when i hit enter they disappear.
Message 4 of 9
engineguy
@jrogers80
OK, it as I thought, when you did the "Extract"for the Gusset shape you left it to default to "join" so it became part of the main body so can`t be moved/copied/patterened on it`s own, I have rolled the extrude back and done the circular pattern for you, all you need to do now if you are happy with what is there you can use the "Combine" facility  to join them all together 🙂 🙂 🙂
Hope this helps, updated file attached 🙂 🙂
Regards
Rob
Message 5 of 9
TrippyLighting
No, it does not.
That gusset/fillet feature can be patterned without a problem.
Message 6 of 9
TheCADWhisperer
@engineguy wrote:
...you left it to default to "join" so it became part of the main body so can`t be moved/copied/patterened on it`s own
Sure it can.  Pattern Feature. (Edit:  I see @TrippyLighting was faster typing...)
@jrogers80
This part is poorly modeled from the beginning.
Would you like to see how to model it correctly?
Message 7 of 9
TrippyLighting
Here is my version:
I created one user parameter, which will allow you to add more holes and gussets by simply editing the number of instances.
Message 8 of 9
jrogers80
yes i would like to see how to model this part correctly.
Message 9 of 9
TrippyLighting
The previous posts had models attached. If you proceed step by step through the timeline you should be able to see how this can be approached.
