Arm rest strat guitar
 Hi can any body show me how to do this curve on a strat guitar PS this is not my work it,s just to show you what i,am takling about. thanks Dave.
Accepted solutions (4)
Replies (8)
mike.mattera
Probably a number of ways to do it, But this is what I would do.  Create a line thru the area you want to cut. Create plane at an angle thru that line. Create a cut shape thru that new plan. Create an extruded cut of the shape.
http://autode.sk/2wYxFmK
Hope that helps.
mike.mattera
Remember this is associative. Change the angle of the line and you change the angled plane. Change the endpoints of the cut curves and you have a new profile on the body. You can play until you gat a cut you like.
http://autode.sk/2vRdCBB
jeff_strater
Hi @Anonymous, this is actually a fairly common Fusion question.  There seem to be a lot of us interested in guitar design in Fusion.  Here are a couple of other threads on this topic:
contour-a-rectangular-model
about-organic-shapes-how-to-model-a-belly-contour-an-a-electric
Jeff
Jeff Strater
Engineering Director
laughingcreek
If you want to gain a little control over the edge created at the top, I would do the same as @mike.mattera, except instead of using a closed profile, draw a spline and use it to 'split body".  that will give you a nice smooth transition on the top.
Hi thank you very much i have been trying to do this for weeks all the
best Dave.
Thank you very much been trying for weeks to do that thanks Dave
Thanks Jeff been trying for weeks to to do that great help thanks Dave
markgutierrez
I like this method for the arm contour. It's quick, easy and adjustable. But I couldn't find a way to adjust the curve of the original 3 point arc.
