Are there advanced camera controls for Fusion 360 available?
Hello out there!
I've recently started working with Fusion 360 professionally to create models and then render them out for product iamges. Now my Problem is the following: I would like to render every single model in the exact same angle but as far as I know Fusion does not support that kind of camera controls. Unfortunately named view aren't very helpful because I can't copy them into other projects. They are only available in the same Projectfile.
Do you guys know if there is a way work around. As an alternative I could use Blender to position my models better and I would have more controls over the lighting but it has more complexity and having it all together in Fusion turns out much easier. At least for me 🙂
Soooo any Idea?
Thanks guys!
twan_peeters
Would it work if you create a dedicated project file for rendering? A product photography Lightbox if you will 😉
So instead of creating the same 'named views' in every project you are working in(which doesn't seem possible), create a project in which you save the views you like and import final models into this space. It also might help to make it easier to render with the same kind of lighting set-up every time you import a project.
Info on importing objects / components into another project
