- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello out there!
I've recently started working with Fusion 360 professionally to create models and then render them out for product iamges. Now my Problem is the following: I would like to render every single model in the exact same angle but as far as I know Fusion does not support that kind of camera controls. Unfortunately named view aren't very helpful because I can't copy them into other projects. They are only available in the same Projectfile.
Do you guys know if there is a way work around. As an alternative I could use Blender to position my models better and I would have more controls over the lighting but it has more complexity and having it all together in Fusion turns out much easier. At least for me 🙂
Soooo any Idea?
Thanks guys!
