- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been using turbocad for a while, but after poor service and support from them a friend of mine recommended trying out Fusion 360.
Hope you guys understand something of what i write.
I build skis and i'm currently trying to learn fusion by drawing some of the skis i make.
The skis i'm drawing now is 182cm with the dimensions (in mm) 133-98-113, and a radius of 21,5m. The center of the ski is at 55% of the skis length, so it's situated at 100,1cm at the 98mm point of the ski. It's really important that the midpoint of the ski (98mm) is exactly on 55% or the ski will become unresponsive when skiing. So, to the problem; When i use either the spline or 3 point arc between tip-tail-mid, the curve of the arc/spline on the midpoint continues behind/below the midpoint making it narrower and offsets the midpoint about 5-6cm. Which will make a huge difference in the skis behaviour. I want the narrowest part of the ski to be at 55% and for the curve to "lift" from that point to the tail. I can somehow use the spline and adjust the tangent to make it"right", but the geometry of skis is quite sensitive to small changes regarding radius and sidecut. Any help or tips will be much appreciated!
Cheers!
