Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Arc Sweeping Problem
2 REPLIES 2
445 Views, 2 Replies
So I'm trying to design a tension coil and I'm struggling with Fusion360's "Sweep" function. I've created an arc from the coil and when I select the path to sweep, Fusion360 sweeps along a circle path that doesn't exist. When I change the arc to a different degree, there is no issue. But when it's just the way that I want it... Fusion360 is all like, "Oh!!! You want me to add random bits to your design? I think this would look cool!" Then it makes my design look stupid and not functional.
Anyway, I've attached a screenshot of what it's doing. Anyone know why it's doing this and how to make it stop and listen?
Many thanks!
2 REPLIES 2
TrippyLighting
You may want to share the model (export as .f3d and attach  post).
I cannot reproduce this, but your workflow might be different.
in reply to: TrippyLighting
Is there a way to save a selection and post it in here? I'm not legally allowed to share the full project file...
