arc/fillet problem
arc/fillet problem
arc/fillet problem
Fillet works on lines but not arcs.
See screencast
  https://screencast.autodesk.com/main/details/5ee54452-4fbc-4496-81e4-e12b414fcb29
Note pop-up box which says "fillet cannot be created"
jiang_peng
I think it's a bug. We will log it and start to investigate.
As a workaround, please see following steps:
Now the fillet:
jiang_peng
Bug logged as FUS-19601
thanks
This still seems to be a problem.
I don't appear to be able to creat a fillet from an arc that has any kind of constrants.
If i make 2 arcs in the middle of no where connected to nothing else I can can use the fillet comand on them no problem but as soon as I draw an arc conected to other elements the fillet comand stops working even if it's between an arc and a straight line.
jiang_peng
Could you please post a screenshot of the new found issue?
Thanks!
Good morning Jiang Peng from New Zealand.
There is a screen shot already posted with respect this problem.
If you need to repeat the problem, just draw two arcs. Then try to put a
fillet across the ends of them. For example an upper and lower airfoil arc
cross-section with a radius leading and trailing edge.
Good luck
Stuart Reid B E (Mech) N Z C E (Mech)
Managing Director
_____
027 240 9691
04 586 3411
stuart.reid@spitfire.net.nz
www.spitfire.net.nz
421 Cuba Street
Alicetown
Lower Hutt 5010
